e-Studio 5008A
  • masterchill
    • Jul 2005
    • 100
    e-Studio 5008A
    Hey have a customer that has a bunch of Toshiba e-studio 5008A that are saying door open please close front or duplex door. I am not familiar with the Toshibas. When you open and close both doors machine makes some noise like it going to clear the message but does not. Machine does react when you push the switches in but does not clear the message. I am guessing this is an issue with this model? Thanks for any help.
    Re: e-Studio 5008A
    have you confirmed that nothing is pushing on the doors a lil bit to keep them from registering the fault?
    could it be that there is a jam inside and not listing it due to "door open"?
    have you done anything besides test the output of the switches?
    • masterchill
      • Jul 2005
      • 100
      Re: e-Studio 5008A
      The only thing I have done was test the switches. I figured it was an issue with this model because out of the 12 machines they have 7 of them are doing this. Did not see any jams. They got these machine in from a parent company that is closing so they are all in a room and they asked if we could check them out so they could use theses machines until lease is up.
      • Vincent128
        • Sep 2015
        • 345
        Re: e-Studio 5008A
        These were moved there from another location ?
        ...They were moved by someone that knows how to transport copiers?
        ...they don't have bent frames ?
          Re: e-Studio 5008A
          Were the prblems reported before moving all to one room?
          Do they have Key Ops trained on basics for each unit?
          I had schools that would assign KO.. found out TWO teachers..would go to the copiers.. if they fucked up.. they would TRY a fix.. ir just leave it down
            • 22973
            Re: e-Studio 5008A
            I've had to re-assemble the right side doorswitch a few times. They're cheaply made push switches that will disassemble itself into (4) pieces when the right door is slammed hard enough. The rear part of the switch stays attached to the wire harness. the front part of the switch stays in the doorswitch holder. The microscopic spring and actuator with comb drop down inside the rear frame. I've been lucky enough twice to find all the parts. I now carry replacements.
            I usually clean the housing outer surfaces with alcohol, make sure the switch opens/closes to 0 ohms like it should, then I epoxy the little bugger together. It doesn't tend to fly part anymore. It doesn't take much 5 minute epoxy to keep it assembled.
            I don't know if you've ever noticed this, but if you have a customer with 10 of the same model machines, all of them seem to have the same problem at the same time. The user that can't get that plywood to feed through machine #1 goes down the hall and tries it in machine#2 ... " I can believe every machine is broke!"
            Actually I can, and it's you.
            • BTech21
              • Jun 2019
              • 12
              Re: e-Studio 5008A
              What color is the rear registration pusher? There was a bulletin that said that static discharge from the registration roller to the rear frame would cause your issue. The updated part is black in color.
              • masterchill
                • Jul 2005
                • 100
                Re: e-Studio 5008A
                I tried to upload a pic but for some reason I cant but it looks like the pushers are white . Does it blow the power board or something? I have rechecked all switches and they are all testing good. The machine does react when you open and close both doors but never clears the open door message.
                • masterchill
                  • Jul 2005
                  • 100
                  Re: e-Studio 5008A
                  Ok to follow up on these machines it was the front door switch on the left. Not being familiar with Toshiba I did not realize they like to use 2 switches for each door. The left door switch was completely pushed in so you could not tell it even was suppose to be a switch and it had all fallen apart into several pieces (junk switch). Yes all seven machines have this issue.
                    Re: e-Studio 5008A
                    well great!
                    one of those issues that will keep locked up in the corner of your brain!
