Toshiba 4515AC E712
  • buzz
    • Aug 2013
    • 288
    Toshiba 4515AC E712
    ADF take up drops down but the rollers and drive motor doesnt turn. New machine.
    Checked for binding, none, (sep, torque limiter, belt drive)
    Any help would be great!
    • 8124
    Re: Toshiba 4515AC E712
    MR3031 RADF or MR4000 Dual Head Scanner?
    • buzz
      • Aug 2013
      • 288
      MR3031 RADF
      • buzz
        • Aug 2013
        • 288
        This is the video of the problem, see above link.
        • arnh79
          • 467
          I wonder if the DF feed roller was installed the wrong way around? It has a one-way bearing in it and if you put it in the wrong way you get the issue you've described.
          Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
          • buzz
            • Aug 2013
            • 288
            re: I wonder if the DF feed roller was installed the wrong way around? It has a one-way bearing in it and if you put it in the wrong way you get the issue you've described.
            Thx but checked that. Also the feed motor does not even turn. Gonna go back there today to check DC voltage to ADF, maybe line voltage to motors in ADF went down. (But just realized Solenoid for pick up works, so wouldnt that be same DC voltage?).
            Any other ideas?
            • buzz
              • Aug 2013
              • 288
              Sensors test fine in F3 Test mode.
              Anyone know the test to check ADF motors, can't seem to find it in the both main body and mr3031 service manuals?
              • didi2005
                • May 2011
                • 401
                I've encountered where when feed using RADF, after press start button to copy the feeding roller will not go down following paper jam code. Found out is RADF board issue...
                  • 22973
                  Have you checked the sensors individually in 03 mode or from pinouts of the RADF controller? =^..^=
                  • buzz
                    • Aug 2013
                    • 288
                    Thx blackcat.
                    03 mode sensors were checked. I even wemt as far as taking apart the ADF down to each sensor to check obstruction of it's actuator spring loaded lever.
                    There are two 24 VDC lines present at the ADF Harness PCB. And no 24 VDC switching at the feed motor.
                    • clint@clintsimonsen.com
                      • 120
                      is the firmware up to date?
                      • BTech21
                        • Jun 2019
                        • 12
                        03-115 should test the RADF motor.
                        • buzz
                          • Aug 2013
                          • 288
                          Yes, updated the firmware to its newest version, thanks.
                          • buzz
                            • Aug 2013
                            • 288
                            Thanks, finally figured it out in 03 test mode. All motors in RADF turns except the feed motor. Ordering PCB to replace and will post results.
                            • buzz
                              • Aug 2013
                              • 288
                              Results: bad RADF PCB. Replaced and all is well. Thanks everyone!
