e455 paper fold mark
  • didi2005
    • May 2011
    • 401
    Have 2 units of used e455c having paper fold mark. Replaced feed & separation roller or swapped whole feeder unit, adjusted the z-fold codes, but problem still persist...
  • clint@clintsimonsen.com
    • 125
    Re: e455 paper fold mark
    Alignment clutch
    Sent from my ONEPLUS A6000 using Tapatalk
      • 23009
      I believe these are the loop settings that I got that worked well:
      • didi2005
        • May 2011
        • 401
        • BTech21
          • Jun 2019
          • 12
          I have seen this issue on that machine. Some times you can disassemble the clutch an clean with alcohol. I would replace the registration clutch.
