e-Studio 3540C C970 error
  • davidbolden
    • Oct 2016
    • 2
    Unable to resolve C970 error.
    Have thoroughly examined all of the charge assemblies, replaced the grids and sawtooth - inspected the posts to make sure they're not broken
    - replaced HV unit
    - replaced all 4 drums
    - replaced transfer belt (it was well worn)
    - thoroughly cleaned the machine
    Still has C970 and a patch of toner on the black drum immediately after warmup
    Running out of ideas without stripping the machine and examining the wiring from the HV board
    Thoughts?
  • toshibaestudio
    • Jun 2016
    • 116
    Re: e-Studio 3540C C970 error
    When dealing with C970, I often check the main charger unit, check any burn mark on the front & rear terminal, sometime the charger rod cleaner also will cause charging issue, where u can try to remove it for testing.
    Since u are having issue on k process unit only, what u can do is to swap the drum unit with 1 of the color process unit and see. If the C970 follow, then confirm is main charger issue. If not, then might be other issue...
    • olddog71
      • Mar 2018
      • 2
      replaced the main charge unit assy. Most likely it's arching somewhere.
