E-Studio 520 toner get stopped in Transport Belt Case.
  • Sbarro
    • 176
    Toner is getting stopped in Transport Belt Case and then forcing Belt Cleaning Blade and get thru the blade always exactly in one place ~7-8 cm from exit. Situation is happen again after few days. I hope you understand what i have written Then we got Drum with scraches in this place after ~200k. I did change Belt, Brush, Blade , vacuum whole pipe and AUGER-TRU. I did run few copies with covers open to confirm that it works.
    We try to speed up (08-455/456 - think so) but it goes even worse.
    Any help ??
    "A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it"
    What do you despise? By this you are truly known"
    Guess who
  • Sbarro
    • 176
    Maybe some photos will clear this up ??
    Guess who
    • tsbservice
      Field tech
      • 8013
      Yes, please I'm interested with your problem but for me description sounds a little unclear.
      • mckinley
        Chief Twiddler
        • Dec 2006
        • 150
        if your transfer cleaner is filling up with toner, either the cleaning system ( brush, motor, etc ) isn't driving, or you have a blockage where the toner drives from the belt unit to the waste box ( on the rear of the machine ) maybe worth checking the waste pipe & mechanism on the rear of m/c.
        if my memory serves me well, 08-455/456 are toner / recycled toner supply amounts.
        Happiness Is The Road.
