Toshiba ES 455 Drum Full of Toner
  • Amincopy
    • Jun 2018
    • 10
    Hi,
    The drum is getting full of toner without any printing and it's shows adding toner message.... after minutes message stopped but drum is still blacked
  • davel
    • Oct 2011
    • 1083
    Re: Toshiba ES 455 Drum Full of Toner
    If drum is full of toner you have problems.
      • 22943
      If the drum has full coverage of toner you probably have primary charge loss.
      If the drum cleaning unit is filling with waste toner and not augering it out to the bottle, you may have a misalignment of the drum cleaning auger coupler with the coupler on the rear frame.
      • BTech21
        • Jun 2019
        • 12
        Check your drum drive and make sure that the roll pin didn't shear off.
        • Amincopy
          • Jun 2018
          • 10
          is it related main charger? nothing is printing.
            • 22943
            Its a bit murky here.
            "Nothing is printing." Could mean:
            1) I don't see the original image, the page is solid black.
            2) I don't see the original image, the page is white.
            Can you be a lot more specific? =^..^=
