Toshiba Cloud Connect
    • 22999
    Is anybody doing Toshiba Cloud Connect? Can you give an overview of how this gets set up? =^..^=
    • 8144
    Re: Toshiba Cloud Connect
    The procedure my vary via country but basically you have to contact Toshiba Tec National Service Dept and register the Serial #s of e5055C series - eBN2 copiers with them before they will be can be uploaded to the secure Microsoft Azure server on which eCloud Connect(ECC) resides. There may or may not be a minimal fee for each copier registered under this service. Toshiba would really like dealers to sample this great advance in remote copier service capabilities which can include remote firmware updates.
    ECC is coupled with the free MFP Mobile Diagnostic Tool (MMDT) 2.0 for rapid analysis of the 03/ 05/08 codes that ECC pulls down from each copier via the Cloud at scheduled intervals.
    As a Security feature ECC cannot contact a copier in the field other than at the exact time scheduled by the local ECC Administrator to upload/ download 03/05/08 data.
    You also need to enable 08-3820-1 to turn on ECC on each copier that you plan to bring under this service.
    • seansbar
      • Dec 2010
      • 198
      Log On
      • Vincent128
        • Sep 2015
        • 348
        Use it and love it.
        You have to take the correct CBT's for cloud connect to be added as a user (I am our admin) - machine either are already added to your dealerships database or there is a link to have the machine added.
        Is used to backup the machines info, backup the machines addressbook, pull down the CSV's and poke into MMDT2 which a awesome.
        I have policies running to alerts us about low/no toner and special customers can 'pay' for the added feature of monitoring error codes
        You can set it up to load firmware's, over ride or alter 05 and 08 codes (I have a group policy for all our setup stuff like fax programs, service contact and phone number, double clicks..etc)
        • tsbservice
          Field tech
          • 7976
          Originally posted by Vincent128
          Use it and love it.
          This sounds awesome especially overriding/altering Service codes, I will use it if available.
          • gliderider
            • May 2015
            • 131
            Just a note to this: If you do have 3820 enabled and are working on the copier you should think about shutting it off temporarily because of the time it takes to run all it's internal processes when the copier has to reboot. You will end up doing a lot of waiting if you are changing 05 codes and the copier then has to reboot and then come back to ready.
