Training
  • Tonerkiller
    • Oct 2012
    • 668
    Training
    I have a question. I work in Pa. If I had to go to a Toshiba copier class, where would that be?
  • guitar9199
    • Sep 2016
    • 1100
    Re: Training
    Not 100% sure...but several companies have East Coast training centers in Atlanta. That'd be my guess.
      • 23008
      Re: Training
      I've been to Toshiba class in Chicago, near O'Hare Airport. I'll get you an address. =^..^=
      Edit:
      8770 W Bryn Mawr Ave # 700, Chicago, IL 60631
      • Tonerkiller
        • Oct 2012
        • 668
        Re: Training
        Edit:
        Thanks, I thought there was one in NJ, but I was not sure.
        • Tonerkiller
          • Oct 2012
          • 668
          Re: Training
          For my area I would go to Parsippany NJ. Does Toshiba have a way to remotely monitor machines? Kyocera has KFS.
            • 23008
            Re: Training
            It's called Toshiba Cloud Connect. We have a guy getting trained up on it now. =^..^=
            • Tonerkiller
              • Oct 2012
              • 668
              Re: Training
              Of course the next question is, how does it compare to KFS? Is that an online course?
                • 23008
                Re: Training
                Thayer: Are you following this? Comments?
                • Tonerkiller
                  • Oct 2012
                  • 668
                  Re: Training
                  I apologize for all these questions, but we are looking into taking on the Toshiba line. We actually had Toshiba install a 4515 in our demo room to try. I trust the information from you guys much more than from a manufacture trying to convince us to take on their product. I would greatly appreciate any input. Thank you.
                  • Thayer
                    • Dec 2017
                    • 107
                    Re: Training
                    Tonerkiller
                    I'm currently learning KFS and Cloud connect(toshiba).
                    They are different but have some similarities.
                    I don't have much experience but i will try to answer any questions you have.
                    • Tonerkiller
                      • Oct 2012
                      • 668
                      Re: Training
                      Originally posted by Thayer
                      Tonerkiller
                      One of the questions is, can I see the status of a machine, right now? An example is a customer calls and says their machine is out of K toner and will not work. I look at KFS and I see that it is actually out of M toner. I know that the Toshiba machine communicates with cloudconnect an night, but can I click on that machine and have cloudconnect look at the machine right now.
                        • 30255
                        Re: Training
                        in house training is always better then video.
                        • Thayer
                          • Dec 2017
                          • 107
                          Re: Training
                          I don't see where you can get a current read, but when it connects it gives a toner level.
                          Customer says black is empty, and you check it says black was 87% but magenta was at 2% at 1 AM.
                          But still learning and if found I will let you know.
                          • Vincent128
                            • Sep 2015
                            • 349
                            Re: Training
                            The toshiba cloud connected machines do a full communication when its time to do so as per policies and settings however - they are live sending event codes, jam, error codes - So for toner levels, jams, errors, meter counts and a few other misc items it is basically up to date information.
                            If you have one connected and the customer does something that creates an event code...say opening the front door...you will see it in cloud connect within minutes
