Toshiba 6550c
  • mansart
    • 855
    [Jamming] Toshiba 6550c
    E010 jam
    I'm looking to replace C0-15043000 / GP2Y5D91S00F, fuser transport sensor.
    I cannot find anywhere, I do not have access to Toshiba direct.
    Any help finding would be greatly appreciated.
    Thank you.
  • gliderider
    • May 2015
    • 131
    Re: Toshiba 6550c
    Open the right side door. Look on the top of it. You will see a black paper guide with ridges on it. It is held on by three shoulder screws. Remove it and you will see the sensor mounted to a bracket in the middle. Note: Be very careful unplugging the sensor from the harness as it can get quite brittle with age due to the heat coming off of the fuser and can literally disintegrate. If it does crumble then you will also need the harness also. Don't ask me how I know this!
      Re: Toshiba 6550c
      so Gliderider ..how DO you know?
      good tip!
        • 23010
        Re: Toshiba 6550c
        Yeah, it's tempting to use hemostats when pulling that connector ... but you can get too much leverage on the hemostats. If the white plastic parts are distinctly yellowed, you might want to just crush the sensor with pliers and carefully remove the bits. The connector is more likely to survive intact.
        I've used this technique successfully on other fuser exit sensors when there was already visible fracture cracks in the connector, and I could already tell it wasn't going to survive. If the sensor is in an advanced state of disintegration it will literally turn to yellow dust before your eyes. =^..^=
        • mansart
          • 855
          Re: Toshiba 6550c
          I know where it is on machine......
          My issue is I'm not Toshiba dealer, and I can't find sensor from any aftermarket vendors.
          Does anyone know where I can buy this sensor?
          TIA
            • 23010
            Re: Toshiba 6550c
            Results for C0-15043000
            • mansart
              • 855
              Re: Toshiba 6550c
              OMG....thank you
              Why I could not find this I don't know
              Phil B. -- Yes I Googled....
              Thank You.
