Looking for a few suggestions on this error. When you put a document in the feeder is displays ready. When you press the start the error comes up and continues to beep until turned off. I have updated the firmware, replaced the ADF cable, ADF board, and sent the SLG board to Hytec for repair. They said it was not in need of repair. Sometimes the ADF will work fine, but then other times it's a hard fail. Any suggestions are welcome. Thanks in advance
copyguy69
copyguy69
