Toshiba 6506ac - Is it fried?
  • pacman
    I can turn a screw...
    • 318
    Received a 7506ac and a 6506ac to get a feel for the AC line
    6506ac
    Turns on
    F101-1 off the bat
    Cannot get into FS diagnostics - comes up F101-1
    Can get into HS diagnostics
    USB port is not detecting when we have a USB drive in for FW
    Swapped the internal USB cable
    Still does not detect USB drive is in
    We are stopped and stumped
    We do know this cable and this thumb drive is good because we just a FW update on a 7506ac. We're at a loss because we can't get around anywhere else in the machine. Thoughts? What are we missing?
    • 8171
    Re: Toshiba 6506ac - Is it fried?
    ... a new e7516AC and e6516AC.
    How many clicks are on each?
    Did the 2nd copier power up OK?
      • 8171
      • davod.mardani
        • Feb 2015
        • 32
        Hi
        Replace HDD and try again for update!
        Best Regard
        Sent from my Mi A1 using Tapatalk
        • pacman
          • 318
          A 7506ac and a 6506ac - NOT new, 6506ac issues off the bat, 7506ac is doing fine and dandy, cannot get meters from 7506ac right now.
          We have the manual, we've done the process
          2. If the error still occurs after step 1, perform the following.
          - Perform HS-73 Firmware Assist mode → Key
          Backup/Restore and check that each Key Status is
          "OK".
          - If not, recover the key (copy "SRAM Key Status" to
          "FROM Key Status" or vice versa).
          This step FAILED. I've tried to upload a picture of what we're seeing the HS mode, but the site doesn't like my pic for some reason (upload of files failed).
          First two keys are broken - HDDENCKEY - KeyBroken and HDDDECKEY - KeyBroken - everything else OK under SRAM and FROM
          Thinking about swapping the SYS board from the 7506ac to the 6506ac, but we are not 100% sure that it's going to break something else.
            • 8171
            Do not swap the board. It is uniquely keyed to the SED-HDD. It is do-able but a whole pile of work and you risk disabling the second working copier.
            If you paid only a little for this used copier, you might want to consider it a parts machine.
            • pacman
              • 318
              That's about where we are with it. We kinda figured that. Unless you, Phil or Blackcat has some magical fix, that is what we'll do
                • 23002
                It's a little bit late for creating board swapping issues, they've already been swapped around. If two or more boards have been changed at the same time it creates very difficult to resolve identity issue. I have second hand knowledge of issues like this being resolved, but don't know any of the details.
                Do you have a tech rep you can call in? =^..^=
                • pacman
                  • 318
                  I don't think we do. However, let me check on that. I gotta make a few calls.
                  We didn't swap the boards BTW. The only thing we changed out was the USB cable thinking it might be a bum cable since the 6506ac wasn't reading the USB.
                    • 23002
                    If the keys don't match it's because the boards had already been swapped out before it came into your possession. =^..^=
                    • pacman
                      • 318
                      Ah HAH! Got it!
