Toshiba 3555c Maintenance
  • buzz
    • Aug 2013
    • 288
    Hi all,
    Looking to put 4 of these on a Maintenance Contract. 2 low volume less than 50K meter each and the other two above 100K meter each. Gonna inspect these in order to see what may be needed prior to putting these on maintenance.
    Would like suggestions and tips to look for and possible common problems and/or issues with this model if any.
    They are using it to scan, fax, print and copy. Also there's no finisher. Dusty construction warehouse environment.
    thanks for any input!
    • 23007
    Re: Toshiba 3555c Maintenance
    Common maintenance items:
    1) Squeaks from the exit assy: Clean that nasty black lubricant from the bronze bushings at the lower exit. The exit shaft may need replacing. Use Triflow on the bronze and plastic bushings, and idler roller shafts. Use Mobilgrease28 or IBM23 on the white duplex idler shafts. Use conductive grease on the 2nd transfer roller ends.
    2) Check the developer unit drive gears. If you see developer in the 35 tooth gear on the mag roller, it's leaking developer. The lower speed machines got plastic bushings instead of roller bearings, and they just don't last. A good developer rebuild includes both augers, (4) ball bearings from the faster series, (4) rubber seals, the (4) gears, and developer.
    Other than the relatively short PM cycle compared to Konica Minolta or Kyocera, they're solid machines that maintain their copy quality well, and not very dirty. =^..^=
    • pacman
      I can turn a screw...
      • 318
      What blackcat said. We encounter the exit assy squeaking CONSTANTLY. We've also had the white idler rollers just kinda disintegrate, but those were fairly high volume units.
      Other than that, I can't think of really anything we've come across that he didn't mention. Solid ADF's, solid system internally, I've never had any network issues with any of them. You should be good to go.
      • Blizzoo
        • Aug 2013
        • 608
        And possible HDD failures (F101 etc). Make sure you have the latest FW on them, they are good machines.
          • 23007
          Since the firmware improvements, I've replaced only (2) Toshiba HDDs in the last 12 months. =^..^=
          • buzz
            • Aug 2013
            • 288
            Can u get by with similar comparable generics for a hard drive or OEM only?
              • 8195
              100% no. Must be a genuine Toshiba SED-HDD. (Secure Encrypted drive)
