toshiba estudio 357 hanged
  • JINACHANDRANS
    • Sep 2019
    • 41
    [Electrical] toshiba estudio 357 hanged
    Dear friends,
    I worked with Toshiba estudio 357 machine. when machine powered ON machine working fine for some copies. after that all functions are getting delayed(hanged) like when i pressed the paper drawer(tray)button it takes one menit for selecting it and while pressing copy start button that also have some problem. i try with new firmware. but the problem is not solved.
    please give me the suggestion to solve the problem.
    Re: toshiba estudio 357 hanged
    Originally posted by JINACHANDRANS
    Dear friends,
    are paper trays set to correct type/size?
    is there paper in the trays?
    what does the copier THINK is in those trays?
    Are there any ERROR messages or code showing on the display?
    do you have clean/proper power?
    you need to give us more info for us to give you aid.
    Phil B. "The Dentist"
    • JINACHANDRANS
      • Sep 2019
      • 41
      Every thing is in correct configuration. copier hanging while taking copies. it hanged nearly 2 to 3 minutes after that it starts working normally for few copies appx 20 copies then again it starts hanged up. at this time i unable to shutdown the machine in proper shutdown procedure, i just switch off the machine by mains and restart the machine. while restarting after this problem machine takes nearly 10 minutes for getting ready. i unable to justify the problem causes.
        well good luck with your problem.
        Since you did not answer my q's I will no longer try to help you.
          • 23006
          Is your MFP networked? If it is not networked it will continue to look for a network, slowing down op panel functions. Under Admin Menu. "Link Down Detection" disable.
            well he SAID all is correct but won't provide basic info.
              • 23006
              I don't know what "... all is correct" means. It's like saying: "I've tried EVERYTHING!!!". Clearly you haven't, because its not fixed yet. =^..^=
              • JINACHANDRANS
                • Sep 2019
                • 41
                You ask about basic things, i checked everything even i upgraded the firmware. i also isolated machine from network, usb cable, printer and scanner dongle, but still the problem persist.
                • Blizzoo
                  • Aug 2013
                  • 608
                  When you updated the FW have you formatted the HDD first? Have you initialised the HDD after FW updated with 08-9030?
