Toshiba 280, 282, 233,283 thermistor needed
  • partly retired
    • Oct 2019
    • 31
    Part # 6lA89105000 Thermistor
    The age of these copiers crept up quickly since today I was told neither Collins nor Precision can't get these anymore.
    Looking for new.
    Re: Toshiba 280, 282, 233,283 thermistor needed
    The age of these copiers crept up quickly since today I was told neither Collins nor Precision can't get these anymore. Looking for new.
    you might get a better response to you needs if you post in here:
    https://www.copytechnet.com/forums/f...ade-or-wanted/
      • 8207
      Toshiba Tec Japan discontinued all support on these models several years ago. Toner, parts and technical support are no longer available from the manufacturer.
      Some of these products were introduced in 2004 and discontinued more than 10 years ago. The manufacturer is legally under no obligation to maintain parts and supplies seven years after the discontinue date.
      Try and find a parts copier or give it up (recommended) and upgrade to a current copier.
