WhatsApp Image 2019-10-23 at 12.12.32 AM.jpgis problem in laser or system???
Registration Colors in toshiba 3520c
Re: Registration Colors in toshiba 3520c
Is that a question or an answer? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
System - replace the entire copier with a different one.
Or perhaps give some actual information about what your symptom is, the steps you took to bring you to the point of giving up and some information about the machine.Comment
last symptom is developer motor replaced than this error appear bout not in every copy one or tow in dayComment
You do know that toner is now discontinued? What are you going to use for toner even if you do fix it? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
