Toshiba 3005AC
  • antone
    • Oct 2014
    • 344
    [CQ] Toshiba 3005AC
    Is there any calibration for the control panel! on the 3005AC
    Sent from my SM-N950U using Tapatalk
  • arnh79
    • 468
    Re: Toshiba 3005AC
    No there isn't. A reboot is supposed to do an auto-calibration. There's also been firmware updates to improve the panel. But I still have a lot of failures which require a full panel replacement.
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
    • Thayer
      • Dec 2017
      • 107
      Re: Toshiba 3005AC
      I found that if I turn off machine. Clean display really well and have up to date firmware helps with display issue.
      • Vincent128
        • Sep 2015
        • 348
        Re: Toshiba 3005AC
        Crumbs and other garbage pushed under the edges of the panel will cause issues as well.
        The firmware update fixed a good deal of it.
        • abc mfp
          • Aug 2019
          • 12
          Re: Toshiba 3005AC
          The first batch of EBN series panels having issue...U can try update firmware, but if error still persist need to replace new type...
          There is no panel calibration, it auto calibrate during booting...
          • Blizzoo
            • Aug 2013
            • 607
            Re: Toshiba 3005AC
            Some Panels may have grounding issues which could cause unresponsive panel/scrolling by itself. If you take your time to disassemble the panel and reinforce the grounding contact of the black cable may help.
            Control panels have been changed for this kind of issues as per above comments.
