estudio 2505ac replace toner error
  • printlessguy
    • Sep 2015
    • 63
    Hello all. got a client with a 2505ac that ran out of black toner. brought a new oem black installed it. it fired up and printed 20 pages out of the que and thought all was ok. an hour later they called and said it is saying replace black toner. had them try the reset by following the info steps. then tried reseating toner. still fails. went onsite with another new toner swapped it out and followed steps. still bad. tried adding toner manually to developer unit. nope put white out on drive gear of toner auger and noticed not turning. any thoughts?
    thanks
    Andy
  • printlessguy
    • Sep 2015
    • 63
    Re: estudio 2505ac replace toner error
    also machine has 44754 black pages and 28876 color pages. when power cycle machine. it powers up fine then starts to cycle and then says replace black toner. even though the toner meter says 100%
    • abc mfp
      • Aug 2019
      • 12
      Genuine toner got chip...
        • 23006
        Is your new cartridge a solid block of toner? Will the drive on the cartridge turn? =^..^=
        • printlessguy
          • Sep 2015
          • 63
          in regaurds to the chip statement. yes they do and so do both of these
          • printlessguy
            • Sep 2015
            • 63
            thanks for the thought blackcat4866 ... 1 toner is a bit stiff to turn even after shaking it the other is easier tho i wouldn't say real easy. if turn little gear which turns big gear on toner is OKish. but cant turn by big gearitself easily on either.
            just tried on the empty can spin big gear semi easily. it is much stiffer on new ones.
            • printlessguy
              • Sep 2015
              • 63
              another thing I just remembered is when I removed the 1st new toner. the chip and its holder had fallen off and was in the space between black and cyan. just got off phone with another local tech and he has seen where the toner drive gear can become stripped. so it wont error out cause the motor turns but the toner auger doesnt.
              • Vincent128
                • Sep 2015
                • 349
                Sounds like you are on the right track - i have not had this specific model's toner drive apart but have seen issues with gear slippage/stripage/deformed on similar - the drive is a little anemic, new toners NEED to be shaken so they can be stirred.
                I know on the 5055c series there was a rash of toner bottles whereby the seal strip would not fully pull out - would brick the toner chips as an empty bottle. Sooo...
                If the bottle is not turning to add toner enough, the copier will write the chip as empty. You seem to have a drive issue or no voltage to motor and that new bottle may still not work and read as empty...sucks too because Toshiba will not warranty the bottles
                • printlessguy
                  • Sep 2015
                  • 63
                  4A 6LJ54816300 GEAR-5H68-6-H21X-J ASD,AUD
                  4C 6LJ54816000 GEAR-5H68-6-H21X-E MJD,CND
                  4D 6LJ54816100 GEAR-5H68-6-H21X-U NAD,ARD
                  all are technicaly the same part. which do I get? j for japan? e for europe? and U for US? so U? and right now luckily the machine says the toners are 100%
                  thanks
                  • Vincent128
                    • Sep 2015
                    • 349
                    Machine version
                    NAD: North America, Brazil
                    MJD: Europe
                    AUD: Australia
                    ASD: Asia, Hong Kong, Latin America
                    TWD: Taiwan
                    SAD: Saudi Arabia
                    ASU: Saudi Arabia, Asia
                    CND: China
                    KRD: Korea
                    ARD: Argentina
                    BTW and FYI for all - this info is 'hiding' in the manual - I remember being confused by the version designation and having a hard time finding it. It's in the manuals at the end of the (2)Specification section - in the 5005ac series SM its on page 2-12 (pdf page 38)
                    • printlessguy
                      • Sep 2015
                      • 63
                      and looking in the service manual .... you are correct. thank you for educating me .. much appreciated.
