Toshiba E- Studio 506 Firmware Update error F101 (4 + 9 or 0 + 8) Not working
  • Yoni
    • Jan 2020
    • 5
    I replaced HDD on 506 E and followed the instruction on the manual on updating Firmware
    When I was doing the firmware update I was only able to do the system firmware update which was from T160SF0W2000 version to the T160SFW1652
    (the one on the USB) and after I updated that I was not able to go back to firmware updater
    mode (by pressing 4 & 9) or 0 + 8 to initialize and I got F106 error so I ended up getting
    another HDD and after installing I formatted it (by pressing C & 3)
    but when I was trying to go back to firmware updater mode (by pressing
    4 & 9) but now I am getting F101 error
    Only C+3 & C+4 is working
    4+9, 0+8 & C+5 not working
    Any Suggestion would help Thanks!
    Re: Toshiba E- Studio 506 Firmware Update error F101 (4 + 9 or 0 + 8) Not working
    1st try updating ONE firmware at a time.. rebooting unit between updates.
    • Yoni
      • Jan 2020
      • 5
      I tried to go update the firmware (by pressing 4 + 9) but it is giving me the F101 error code is there any other way
      I have the firmware ready on USB drive
        Don't do BATCH upgrade do one at a time!
        • clint@clintsimonsen.com
          • 125
          C+3 check the keys you will probably have to reformat again but also transfer keys, I take it the hard drive is one of the wipe drives as if the machine has had a wipe type drive in it and you are trying a non wipe drive it will not work.
          Sent from my ONEPLUS A6000 using Tapatalk
          • Yoni
            • Jan 2020
            • 5
            Thank you for the replay
            Forgive me but I have little experience on firmware upgrade
            I couldn't find any clue on the service manual on how to upgrade the firmware one at a time, I only see the (4+9) batch upgrade option and thats is not working in this case
            Please send any suggestions I can try
            Thank You!
            • Yoni
              • Jan 2020
              • 5
              The first HDD I tried was a non wipe drive, I was getting F106 error with that one, So I replaced a second HDD that is Wipe drive (exact match with the original) but I am having the F101 error this time and I will try your suggestion and reformat again
                • 125
                When it comes up with F101 what is the sub code?
                • Yoni
                  • Jan 2020
                  • 5
                  Thank You very much! your suggestion worked
                  I reformatted 2nd time and I was able to get back (4+9) option to come back
                  sub code is 1
                    • 23010
                    Me too. It absolutely must be a Wipe Drive. The F106 means wrong kind of drive.
