Toshiba E-452 Finisher Swap
  • Tim C
    • 167
    I have a E-452 missing a finisher... So I swapped one with a E-450 and had to change the mounting bracket to fit,, ERROR after startup.
    Is there another Finisher I have to use. The one I have on is the MJ-1023
  • tsbservice
    Field tech
    • 7988
    E-450 use MJ-1023 and MJ-1024.
    E-452 use MJ-1024 and MJ-1101
    • Baphomet
      Copier Technician
      • Aug 2008
      • 293
      My friend tsbservice is very close to correct. Both 450 and 452 can use either the MJ1023 or the MJ1024 finishers with no modifications.
      The 452 can also use the MJ-1101, and there is your problem. Since you stated that you had to change the brackets, that tells me that the 452 used to have an MJ-1101 installed on it.
      You need to go into 08 mode and change code 1912 to 0.
      0 = MJ-1023/1024
      1 = MJ-1101
      You will also need to install the IPC board for the MJ-1023/1024 on the logic board.
      Hope that helps.
      • tsbservice
        Field tech
        • 7988
        My friend Checker is absolutely correct
        According to sales config docs I posted wrong information, sorry.
        SH states that Great Guru is dead on spot, please disregard my post.
