E-255 Scanning quality issues
  • deputydogg
    • Nov 2015
    • 172
    It has a MR-3021 RADF. Randomly(more times than not) when you scan/copy using the ADF it will have random blurred lines(front to rear, not lead edge to trail edge) on the copy or scanned image. Some of the mylar strips were torn or missing so i replaced them, I thought maybe they were causing the document to stall slightly but it didn't help.
    Any suggestions ?
    Thanks,
    Dave
  • Vincent128
    • Sep 2015
    • 349
    Re: E-255 Scanning quality issues
    without a scan of the issue to look at and or more info - I would guess perhaps you are loosing drive somewhere in the paper path.
      • 8220
      All technical, parts and consumables for this copier series officially ends this month 03/31/2020 from Toshiba Tec Japan. This copier was discontinued more than seven years ago.
      Time to think about upgrading to a current copier or at least an e257.
      • deputydogg
        • Nov 2015
        • 172
        • abc mfp
          • Aug 2019
          • 12
          I will narrow down the issue by scanning both RADF and platen glass, if both got issue, then i will check on the scanner carriage cable...
            • 23009
            I'm leaning towards a drive issue in the MR3021. =^..^=
