Toshiba 2050C control panel not responding to buttons and touchscreen presses
  • jim1234
    • Dec 2019
    • 8
    • 8206
    Re: Toshiba 2050C control panel not responding to buttons and touchscreen presses
    It is possible that the silver shielded cable that connects the LCD panel to the main board is damaged.
    • jim1234
      • Dec 2019
      • 8
      So I checked the cable, and it looks intact.
      • jim1234
        • Dec 2019
        • 8
        The problem turned out to be a corrupt hard drive. The problem was solved by formatting the entire hard drive in 3C mode and reinstalling the firmware.
        I tried replacing the SYS board and power supply board, and neither solved the problem. I tried various hard drive recovery techniques (recover F/S, formatting the root partition, etc) without success.
          • 23008
          Just today I had an e Studio 356 that would boot to "Ready", print, and receive fax. But if you touch any control panel button or soft key, the machine would display "Shutting Down." like I might have pressed the Power button. If you don't touch the panel it stays on, "Ready".
          I treated it like a failed HDD. Fortunately, I had saved a previous NetScan that provided the IP address. From the web interface I was able to create a clone file and save it back to my laptop. I was able to navigate 3C, 49, and 08 modes without a problem. From then on the panel acted normally, so I had no difficulty entering the IP, importing the clone file, and the 05 mode image calibrations.
          I believe that there was a corrupt sector on the HDD. When the panel was touched, I imagine the the MFP trying to access a corrupt command. =^..^=
          • jim1234
            • Dec 2019
            • 8
            Wow, that's tough one too!
            I didn't even think of grabbing a clone from the web interface! I'll have to remember that in the future. Thanks!
            The machine I was fixing did respond to pings, and print jobs could be sent to it from a computer, so I know the network interface was functional.
