Toshiba 3511 C360 Code?
  • CopyDawg
    • Dec 2008
    • 74
    Anyone know what C360 on a Toshiba 3511 is?
    Thanks!
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1898
    It means time to sell them a new machine. Just kidding, I hate working on those.
    [C360] Charger cleaner motor abnormality
    (1) Check if the main charger is installed normally.
    (2) Check if the charger wire is broken.
    (3) Check if any of the connector pins of the charger cleaner front/rear position detection switch is
    disconnected.
    (4) Check if the cleaning pads are damaged or removed.
    (5) Check if any of the connector pins of the charger cleaner motor is disconnected.
    (6) Replace the charger cleaner motor.
    (7) Replace the LGC board.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
