Printing white lines (toshiba e-studio 6570c)
  • omorales
    • Mar 2015
    • 86
    Hello friends, I wanted to know if someone has had this problem, attached image.
    The fusion kit and the transfer belt were changed because they were in poor condition.
  • clint@clintsimonsen.com
    • 124
    Re: Printing white lines (toshiba e-studio 6570c)
    Looks like a charge issue. Check the 1st transfer roller holders some times the clips break. Or the springs at the rear of the EPU tray get dusty. Also Tosh do have issues with damp paper.
    Try the internal test pages
    USER FUNCTION => #1048# Hold down the last # untill network initialisation appears on the bottom of the screen the password should be blank.
    Sent from my ONEPLUS A6000 using Tapatalk
      • 23007
      The four basic things I do on every quality call on console color machines:
      #1 Inspect/clean/replace needle electrodes and grids.
      #2 Manually clean laser slit glasses
      #3 Check developing roller(s) to identify any voids in the developer brush.
      #4 Perform color calibration.
      • omorales
        • Mar 2015
        • 86
        Thanks friends for the answers.
        What solved the problem was the change of the laser mirrors.
        Thanks for everything.
