Toshiba e-STUDIO 35, cannot change paper size
The asterisk simply means that the cassette is reserved for special use. To clear the special use (asterisk) press JOB STATUS, CASSETTE, then at the bottom of the display select NEXT then select your tray on the left, and de-select whatever special designation is highlighted on the right. That's all there is to it and this is in the user's manual.Comment
Pull the drawer all the way out and check for paper stuck in the paper detect sensors.
Sounds simple, but I had a customer pull the drawer out and left a stuck chunk of paper wedged in the leaf spring.Why do they call it common sense?
If it were common, wouldn't everyone have it?Comment
