Toshiba 5055c weird lines
  • badrobot
    • May 2020
    • 22
    We keep getting weird lines on the top of each page, 8.5" side, regardless of what is printed. I have checked the toner waste box, drum and such. Can't seem to figure out where it is coming from any ideas would be appreciated.
  • Blizzoo
    • Aug 2013
    • 608
    Re: Toshiba 5055c weird lines
    I suspect this is caused by the K Developing unit - look at the magnetic roller. Your developing roller could have some 'play' at the back side where the gears are this due to worn out developer roller shaft. The bearing gets stuck and eats the shaft.
      • 23007
      Whats the repeating interval? I like the black developing unit too. You'll want (4) bearings (not bushings), (4) seals, (2) augers, (4) gears, and black developer. =^..^=
      • Blizzoo
        • Aug 2013
        • 608
        I know you are very thorough Blackcat when it comes to such info but I don't have it for you but I recall it wasn't a such exact interval on my occasions. That's why I assumed from the poster pic it may be what i've seen.
        Done loads of dev units rebuilts especially on 3555 - these have the plastic bushings as you know and the bearings replacement plus all the above mention are the real long term fix.
        I've seen many 5055 with failed auger bearings at about 250k or more per dev unit, mostly black ones. ATS Sensors must not be overlooked, they got scored or get toner buildup
        • tsbservice
          Field tech
          • 8008
          [ATTACH=CONFIG]46045[/ATTACH]
          You should state machine total counter and consumables life but I have to agree with guys.
          I have done tons of developer units rebuild on older models like dp3500 and so on.
          Sadly Toshiba seems to replicate their downfalls on newer models. Seals are leaking developer wearing mixer shafts and mag roller shafts, not to mention seizures of bearings and damaged gears.
          Not to even mention developer spilled into machine and eating drums due to worn spacers.
          Ohh, what a days that was...
