TOSHIBA Copier E-Studio 857 can not work!!! Please help!!
  • monslytherin0101
    • 3
    [Error Code] TOSHIBA Copier E-Studio 857 can not work!!! Please help!!
    Hi!
    My Copier ToshiBa E-Studio 857 does not work when I press START.
    I can choose the number of copies but it does not copy.
    I also can not "Factory Reset" due to the button is blurred.
    I attacked a link to a video to show you how it was.
    VID20200823200328.mp4 - Google Drive
    I acquired it as a used copier. I live in Vietnam that we usually import copiers from others.
    Actually, I have a friend who has a E-Studio E-857, too. His copier works well.
    I tried to change systems board include HDD with him, and my systems board also works well with his copier but when I set his board to my copier, that problem still happen.
    Please help and give me some solutions!!
    Thank you so much!!!
    • 8197
    Re: TOSHIBA Copier E-Studio 857 can not work!!! Please help!!
    Likely the system software on the copier's hard drive is corrupted.
    There is nothing you can do.
    You need to call in a trained Toshiba service technician to reload the software.
    What is the meter read on the copier?
    Was the copier purchased as 100% new or did you acquire it as a used copier?
      • 23008
      My first attempt would be to re-format the HDD and re-load firmware. You'll want a technician to do this.
      If this fails you might have a bad HDD or logic PWB. =^..^=
      • monslytherin0101
        • 3
        Hi!!
        Thanks for some solutions!
        To reply you, I acquired it as a used copier. I live in Vietnam that we usually import copiers from others.
          • 23008
          You cannot just swap boards or HDD's on Toshiba machines. Each board and HDD is married to the other boards. There is a very specific procedure to replace only a single electronic board or HDD, never more than one at a time. Additionally the data on the HDD is encrypted with a unique encryption password. So a fully functional HDD on one machine will not work on another machine until it is re-formatted and firmware reloaded.
          You REALLY REALLY need a technician who knows what they are doing before you brick the machine for good.
            +1
              • 8197
              I would say it is now not economical to repair this copier.
              Once the user started swapping system boards and HDDs, it would take a highly skilled tech working closely with qualified tech support to bring it back.
              Either the System board of the Toshiba proprietary SED-HDD needs to be replaced. Easily $800.00 USD + labour.
              This is certainly not something that can resolved by asking for free tech support on the web.
              Too bad as the e857 was a really good copier before it was discontinued in Aug 2016.
              • monslytherin0101
                • 3
                Thanks for your help!
                This morning, I turned on it and it worked.
                In the afternoon, I shut down it when I turned on again, I felt that the power seemed like "low in a moment" when the machine was turning on and checking systems.
                I am trying find a fully-skilled technican but quite hard due to in my country, we usually import copiers and we almost meet error codes about hardwares.
                • mgipa
                  • May 2020
                  • 49
                  Originally posted by monslytherin0101
                  Hi!
                  08 -9090 set 0
