Problem with e_studio 757 (dot on printed paper)
  • V_a1900
    • Sep 2020
    • 5
    [Misc] Problem with e_studio 757 (dot on printed paper)
    hello.
    we have problem with toshiba 757. during computer flattening and printing slowly at the same time, we havent any problem. but if we pull out the paper and wait for fellatening, then put back paper in, print will be start fast and some dots show up on printed paper. In service mode and using 2020 code, if we take down number printed paper is ok but colerless.
    there is photo of this issue below.
    • 22698
    Re: Problem with e_studio 757 (dot on printed paper)
    Take a look at the trough in the bottom of the drum unit. If it's full of toner, the developer is overtoned. =^..^=
    • V_a1900
      • Sep 2020
      • 5
      Hi. Thanks for answering me. Yes, there was alot of Developer. How can we stop that? Whats the reason of this problem?
        • 22698
        I think I'd replace the C6000 developer. The developing unit is probably fine. =^..^=
        • V_a1900
          • Sep 2020
          • 5
          We have problem in both sides print. On first page we haven't problem but the other side we have (dots) very little.
          I checked the drum unit again and its ok.
          • arnh79
            • 459
            Like blackcat said, replace the developer material. Your symptoms indicate that the developer material is worn out.
            Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
            • MarioTech
              • Jul 2020
              • 40
              Originally posted by V_a1900
              hello.
              [ATTACH=CONFIG]46824[/ATTACH]
              I agree with the rest of the guys, however I only see developer on the front side of the drum unit. Did you vacuum the rest or was it only piled up at the front? I see a line on the drum as well that might be pulling developer on that particular spot if it's only piling up there, these units can be pushed on the drum and developer material a few hundred thousands tops after that you'll have to PM the unit. Otherwise you'll be going in every next week to clean the mess and have an upset client. In regards speed, I suggest you update the latest driver that dates July 2020 and the latest firmware version 1286 came out December 4th 2019. Isolate the file you are printing or test different applications if they are all the same in regards speed from clients PC or laptop, use same files from your laptop connected directly into the copier and compare speeds. Try using different files and compare as well, maybe their files are corrupt and that'll show up when you run these tests. Reset the 06 once you replace drum so the unit compensates accordingly to new consumable. Hope this helps!
                • 22808
                +1
                • V_a1900
                  • Sep 2020
                  • 5
                  Thanks to all. I will change developer powder and sharing result with you.
