e-STUDIO2500AC Lifetime ?
  • MadFlasher
    • Sep 2020
    • 3
    Hello ! it's Mr Newbie here
    A friend will get a free e-STUDIO2500AC from an abandonned rental (yes, sometimes they don't get back the old copier and leave it as this...)
    I download a lot of specs and user manuals but don't already find if this copier is old, very old, or just a trashcan...
    Some counters numbers :
    Total scans : 95.000
    Total prints : 270.000
    What do you think about this e-STUDIO ?
    In general where can I find theses informations ? service manual ?
    Thank you very much for yours comments !
    Stephane (from france)
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    Re: e-STUDIO2500AC Lifetime ?
    LIFETIME 6 YEARS
    • Introduction Date: 05/2016
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
    • MadFlasher
      • Sep 2020
      • 3
      Originally posted by rapidocument
      LIFETIME 6 YEARS
      I'm sorry, perhaps "lifetime" is a translation mistake ?
      I know for electro/mechanicals devices there is no expiration date but "lifetime" is in correlation with number of uses
      There's probably some problems with caoutchoucs parts who's can degrade (even used or not)
      So, with 260.000 prints do you think it's a copier middle life ? end life ?
      Thank you ;-)
        • 8220
        270k is middle to long life if the copier has been well maintained.
        If not, the copier could easily require $500.00 in parts plus labour to extend the reliability and image quality for hopefully another 100k.
        If you power on the copier while holding down 9 & Start key, the copier will beep. Then enter 103 and Start key.
        The copier will print off its Preventative Maintenance list giving you a good indication what needs to be replaced.
          • 23009
          About the only way you can run this machine for any length of time, is to start your own K2 graveyard. If you buy 6 or 8 of these corpses cheap, maybe you'll have enough parts to make one of them work for a while. New parts are as rare as hen's teeth. It will be an exercise in frustration for you. =^..^=
          Edit: Wait a minute! Is this a K2: e Studio 2500C or a Weisshorn Low: e Studio 2500AC?
          The Weisshorn Low is definitely newer, and parts still available, but that's medium to high count for a light duty machine.
          • Blizzoo
            • Aug 2013
            • 608
            He needs to enter FS mode to access 9S List Print to print those maintenance sheets counters. Don't think he can get straight into 9 and Start mode unless the control panel has a Key Panel option installed? Never seen this option to any customers so far so I could be wrong..
            • MadFlasher
              • Sep 2020
              • 3
              Thanks to all !
              it's a e-Studio2500AC
              I'll bring it to office tomorrow and i'll check maintenance list
              I'll be back here with informations
                • 8220
                Originally posted by MadFlasher
                Thanks to all !
                I hope you do not plan to lift it several times just to print off a maintenance report.
