ES 4505ac Color streaks when copying
  • pontiac
    • 420
    Doing a customer a favor on a Toshiba 4505ac replaced all four drums calibration sheets come out very clean print job come out very clean only when copying cyan and magenta streaks appear Fine Lines clean the Optics two times am I missing something thanks for replies
    Re: ES 4505ac Color streaks when copying
    post examples
      • 8197
      Why did you replace all four drums?
      Did you replace the Developer as well?
      What are the clicks on the copier? How many scans?
      Did you print the internal test chart from FS Mode?
      What type of Doc Feeder is on the copier? RADF or Dual Head MR4000?
      Did you use the alignment pins attached to the back of the Doc Feeder to make sure the Doc Feeder is on square to the copier?
        • 23008
        Did you do a color calibration? Lets see samples:
        • pontiac
          • 420
          When I mentioned doing a customer a favor I meant a favor we service canon, no knowledge on these things but what is on you tube. customer supplied oem drum and blade any way I swapped the drum unit s from another 4505ac same lines tested rebuilt unit on second box and no issues when making copies or prints. Thanks for replys
            • 23008
            it makes a large difference that you did not:
            Reset the consumable counters
            Clean optics and laser slit glasses
            Run a color calibration.
