Duplexing not avaiable
  • Valintine
    • Jan 2012
    • 147
    Hello
    I have a new one to me at least. I have a customer with a Toshiba es287c. They received a message to replace toner. After replacing the toner it called for a drum which they installed. Now when they try to do a duplex copy or print they can not. I had them try with me on the phone and the say the 1-2 and the 2-2 are greyed out and not avaiable. I looked for a setting in the admin mode to restrict this but I am coming up empty. I have heard of disabling single simplex coping but not duplex. Any help will be greatly appreciated.
    Re: Duplexing not avaiable
    Originally posted by Valintine
    Hello
    sounds like there is a error code not being reported to you.
      • 22930
      Yes, take a look at 9S-106 or 9S-107 error list. =^..^=
      • Blizzoo
        • Aug 2013
        • 594
        Hello
        They must make sure the duplex unit is installed properly into the main body hence the reason duplex options are greyed out. Duplex unit connector may be broken or out of place in worst cases, I had this before.
