Toshiba 5055C
  • badrobot
    • May 2020
    • 22
    [Misc] Toshiba 5055C
    So I wanted to look the Drum over as I am getting some marks on the print. I remove the appropriate pieces and it appears the drum is just locked in there. I don't want to break it. To make sure I am doing things right I also tried to remove a couple of the color units and had no issues.
    I am not 100% sure on what is locking it and or the steps needed to be done in order to release the lock. The copier still works thing, but I know eventually this will be an issue.
    Any help would be appreciated.
    I did see this -https://www.copytechnet.com/forums/toshiba/139144-e-studio-5055c-cant-remove-black-drum-tb-unit.html
    But I am not sure what they mean as to transfer belt release. Or where it is located.
  • Vincent128
    • Sep 2015
    • 349
    Re: Toshiba 5055C
    Acquire Service Manual, Study the disassembly section, report back with findings, assistance will follow.
      • 23008
      Re: Toshiba 5055C
      You can see it on pages 137, 141, 142, and 163 of the service manual.
      Independence and doing your own manual reading is highly prized here. Though, to be completely fair, It's not ever named or referred to in the text. So all you've got to do to redeem yourself is say that you looked in the manual, but could not find any details.
      EDIT: Oops!! Too late. You could have found it on page 224:
        Re: Toshiba 5055C
        [ATTACH=CONFIG]47016[/ATTACH]
        [ATTACH=CONFIG]47017[/ATTACH]
        you da man!
          • 8197
          Re: Toshiba 5055C
          ... just watch this very helpful video from a copier technician!
          Toshiba eStudio 5055 Drum Unit Rebuild - YouTube
          • badrobot
            • May 2020
            • 22
            Re: Toshiba 5055C
            Thanks for the help!
            I do have a copy of the service manual and I did look. I have to admit this one was a tricky one. I don't know if I would have saw that lever an turning it clockwise part. I do look prior to asking, just sometimes it is hard to find the specific aspect or part I need. Usually if I do a ctrl + f in adobe I can start to look for things and generally find my way. I think in this case when I got stuck I started to do a general Google search, which in turn showed most Toshiba copiers having a larger green lever for that aspect which just made me more confused.
            I was able to get the Drum aspect out, an clean it to get a better print.
            Again thank you for taking the time to help!
              • 23008
              Re: Toshiba 5055C
              I always start with control + F ... and got nothing. So you're off the hook this time.
              Congratulations on your success!
              • Vincent128
                • Sep 2015
                • 349
                Re: Toshiba 5055C
                That Ctrl +F is making us all dumberer !
                ..buuuuuut..it is better now that I don't have to have sacrifice half my trunk space to physical mannuals.
                  • 23008
                  Re: Toshiba 5055C
                  My entire trunk was jammed with paper manuals. But can you imagine browsing a 3000 page paper manual?!
                    Re: Toshiba 5055C
                    Ahhh the good ole days! [emoji1787]
                    • Vincent128
                      • Sep 2015
                      • 349
                      Re: Toshiba 5055C
                      Only 3K ? my manual for the KM7075/85 were 2 5 inch D-ring binders and 3 inch for extra stuff. Back then I drove Ford Ranger extended cab. The cab was completely full of manuals and 3 truck boxes in the bed for my stock.
                      ...I'll tell you this though, I do miss having a huge ass fold up components map and electrical diagrams ... Printing them in poster mode on 11x17 and taping them together is just not the same.
                      • mojorolla
                        The Wolf
                        • 2609
                        Re: Toshiba 5055C
                        Panasonics used to have these, called Torano Maki or something similar. It was as big as a table cloth and had a readable wiring diagrams on one side, and error codes on the other.
                        Another thing I "used to have" was the county wide street guides (before GPS). I had an entire box of these and as my territory expanded, so to did my street map library.
