Toshiba estudio 2050c
  • afterhours
    • Mar 2017
    • 152
    Hello, I was wondering if anyone can offer suggestions regarding an issue with lines showing up on a Toshiba 2050c. I'm a Konicamimolta tech and am trying to fix this toshiba for a friend. I've posted pictures of the issue. At first it was just cyan lines so I thought it was a bad drum, but now it has black lines as well.
    Any help would be appreciated.
    Im a Loser Baby!!!
    Re: Toshiba estudio 2050c
    pics are too small for me to see.
    it could be ITB 2PTR
    have you done a stop test?
    what do the dev units look like?
    what have you done?
    copy or print?
    how many pages on the PM parts?
    Phil B. ' The Dentist '
    • afterhours
      • Mar 2017
      • 152
      Thank you.
      I'll get that info tomorrow.
      But if you were able to see the lines in the pictures I uploaded you'd see they are very unusual. As if 1 thing is causing them all. But the transfer belt looks good visually.
      Sent from my SM-G981U using Tapatalk
      Im a Loser Baby!!!
        Thank you.
        like i said in my 1st comment, pics too small
          • 23010
          I'd start with a new black needle electrode and grid. I think that when you look, you'll see that the black grid has a heavy layer of light green corrosion. Clean the optics and do a color calibration and post back.
          The color of the lines is ~22% black, and the other colors negligible.
          • djbass
            • May 2008
            • 167
            Those lines are definitely coming from either the main charge grid/electrode on the drum or the mag roller on the developer assembly, what I can't figure out though is why the lines are wavy.
            No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
            • afterhours
              • Mar 2017
              • 152
              That's what looks so unusual to me also. I cleaned the grids and electrodes yesterday and so far no more lines.
              Im a Loser Baby!!!
