toshiba E Studio 555. code F070 need to reset
  • clark
    • Sep 2016
    • 109
    I have a customer with the toshiba E Studio with a service code F-070. Can someone help with the resetting of this machine. Thanks
  • Thayer
    • Dec 2017
    • 108
    Re: toshiba E Studio 555. code F070 need to reset
    [F070] Communication error between System-CPU and Engine-CPU
    (1) Check if the connector CN104 on the SYS board and CN130, CN131, CN134 on the SYSIF
    board is disconnected.
    (2) Check if the connector CN10 on the SLG board is disconnected.
    (3) Check if the harness connecting the SYSIF board and SLG board is disconnected or open
    circuited.
    (4) Check if the harness connecting the SYSIF board and LGC board is disconnected or open
    circuited.
    (5) Check if the connection of the SYS board (CN104) and SYSIF board (CN130) is open circuited.
    (6) If the SYS board has been replaced, check if the jumper pin setting on the SYS board is correct.
    (The jumper pin should be inserted between pin 2 and 3 of CN103 and CN115.)
    (7) Check the version of the system ROM on the SYS board.
    (8) Check the version of the engine ROM version on the LGC board.
    (9) Check the version of the scanner ROM version on the SLG board.
    (10) Replace the SYS board.
    (11) Replace the SLG board.
    (12) Replace the LGC board.
    (13) Replace the SYSIF board.
    • aalex_bom
      • Jan 2008
      • 214
      The mouse maybe bite wire somewhere, check connector all
        • 23010
        It sounds to me like you've got a paperweight. =^..^=
        • mgipa
          • May 2020
          • 49
          check LGC board and PSU
