Oki CX3535T / Toshiba E studio 3540c CA00 Error Code
    • 8197
    Re: Oki CX3535T / Toshiba E studio 3540c CA00 Error Code
    Originally posted by Vincent128
    Our office color copier is still one of these - they last and last and are built like a brick shitter . (I have one more in my bone yard for backup)
    I'd take a field full of these over all the problematic 5055c's that replaced them with their exploding developer units or the 05ac /15ac's with their very inflated developer cost.
    I gave up on pricing out replacing developer and rebuilding the UI's one the newer color boxes..it's 'cheaper' to just buy the entire IU...even still that puts a full color PM at $3000 our cost !
    I had so many of these out in the field that literally never had any service calls other than a doc feeder roller or a tray roller...I'll be sad to see it go fully. (only have 3 currently out in the field with active contracts)
    ... a lot of service techs in my area had similar sentiments about how great the e3540c series was.
    Compared to the current e5015AC series, these old copiers were heavy, overly complicated pigs to work on. We even cleaned out our copier graveyard of these models as we have none left in the field.
    • Vincent128
      • Sep 2015
      • 349
      Wonder what made them pigs ?
      All mine ran clean while the new ones dumped toner all inside all the time.
      They are heavy, i'll give you that.
      Also not sure on the overly complicated - I feel they are easier to work on than the new ones with the exception of the laser shutter assembly - It's a bit of work to get out of the machine.
      *shrugs*
      • tsbservice
        Field tech
        • 8014
        *shrugs*
        That's the difference between true engineers and sales guys.
        Imho if parts and consumables are still available there is absolutely no need to throw out good working for both customer and service copier just to satisfy salespeople.
          • 8197
          #19
          Service people would not have jobs if salespeople did not have new and better stuff to sell.
          • tnrtt
            • 156
            #20
            Most of the time I've had that code on one of those, it's been from the transfer belt cleaner disengaging.
            • Rusty.Harris
              • Jan 2021
              • 631
              #21
              Have you tried 08 mode, 4546 to disable the color registration? If it works fine, then go into input/output mode, 03 and check the
              sensors.
              Also...just remembered this one. Drove me nuts! Does the machine have any accessories? LCF, Finisher?
              If so, PLEASE check the 5 volt power supply line. Easy way to find it. Pop the top off the ADF, the larger connector coming from
              the machine to the ADF, locate the wire harness connector to the ADF board. The larger yellow wire is the 5v DC line. Check it.
              If it is below 4.92 volts, THAT can trigger the issue as well. On the older version of that machine, the DC power supply had adjustable
              pots, but in the newer version, they took the adjustment out. The switching regulators in those, were not really up to the load requirements
              when the accessories were added. Also, they had some batches of sensors that were troublesome and would "freeze" until powered off/on.
              Once we started cranking the 5 volt line to around 5.1 under load, a lot of are whacky goofy problems stopped. But, like I mentioned,
              some of the newer designs took the adjustment for the LVPS away.
              Originally posted by bdesire
              Thanks for all the replies, when I figure out the problem I will post it. The Black and Color maintenance kits have been installed with no change. The error code shows up immediately after the machine records the patches on the transfer belt. The machine won't allow printing or copying except In maintenance mode, it comes to ready to copy, performs a check of the transfer belt and right into the code. According to the client the machine worked fine in the morning and no response when trying to print in the afternoon. I will post what I find. Thanks again.
              • Blizzoo
                • Aug 2013
                • 608
                #22
                Hmm, I would check the Laser Unit, considering the age of the machine. I had to clean many of them being dusty. Easy to check is open the LSU Shutter and shine some light over the slit glasses, you would probably see them pretty witheish
                • tsbservice
                  Field tech
                  • 8014
                  #23
                  sensors.
                  Hey Rusty good call. I now remember mine old battle with an estudio 35 DF false sensor reading and it was power supply that I had to replace...not ask me how I figured that out it was long time ago.
                  • yormets
                    • May 2009
                    • 336
                    #24
                    Been renting the 3040C and the 3540C machines for years now. Very few problems. Drum units go bad. I just purchased some back up parts machines and have made a fortune of those Toshiba's. Sorry to see them fading away.
                    • Rusty.Harris
                      • Jan 2021
                      • 631
                      #25
                      Yeah, it was something that drove me nuts when it first started. One tech came in after working on an ADF on a 230 series. He said the
                      same sensor went bad 2 times. I said once is unusual...TWICE is a trend. I had him take me with him when it happened a THIRD time.
                      Checked the outlet, checked ok. Then I went digging. AC, 24v, 12v ok but when we checked the 5v, it was just a bit off and when we started
                      running it, it went lower. Cranked it up to 5.2 and it never did it again. ANYTIME we had a strange issue, first thing I would have them do
                      was to check the 5.1 volt line. EVERY time, it was low.
                      Cheap switching regulators... Then of course they took the pots off of them so you couldn't adjust them. The 3540's were the first ones I
                      think that didn't have the adjustment pots. Of course ATSG didn't or wouldn't give me the schematics. I'd just swap out the resistor on the
                      switching regulator to boost the voltage.
                      • bdesire
                        • Oct 2012
                        • 62
                        #26
                        In service mode 08, key in 4546 and set it to 0. This will turn off the color registration. Power back up
                        and run a color copy and see if it is off. Better yet, run 04 mode, and run 204, which is all colors in a
                        grid pattern and see which one(s) are off. On that machine, yellow is fixed, and the other 3 colors are
                        referenced to yellow. Then, try running 05 mode 4720 to tell you which color the machine thinks is off.
                        It could be any number between 1 & 255. The number displayed tells you which color, along with if it
                        is the rear or front sensor.
                        I've had CA-00's come up before, turn off 4546, and the copies look perfect. But, if you run each color
                        one at a time in 04 mode 220, you will see a thin white line through one of the colors. If the color is
                        missing in the right spot, the calibration print looks like "bird feet" (>) If part of the arrow is missing,
                        it will trigger the CA-00.
                        • Rusty.Harris
                          • Jan 2021
                          • 631
                          #27
                          That's odd...08-4546 is suppose to tell the machine to NOT do color registration. Here's something you might try.
                          Set 08-4546 to zero. Power off the machine. Open the front door, power on the machine. Let the screen come up
                          to the point where it says "close front door" after the splash screen. Close the door and see if you can get it to
                          a ready state then. Have you also tried to reflash the firmware?
                          Also, I had a 3540 series machine that was in an industrial steel plant area that was constantly having image CQ
                          problems. I tracked down the CQ issue in the laser. Dust was accumulating on the mirrors along with the polygonal
                          mirror. (dust actually etched the mirror). What I ended up doing was getting some foam tape, and took the cover
                          off the laser, sealed along the edge of the laser cover, and, along the heat sink for the mirror motor. Never had another
                          issue.
                          • bdesire
                            • Oct 2012
                            • 62
                            #28
                            issue.
                            [ATTACH=CONFIG]48399[/ATTACH][ATTACH=CONFIG]48400[/ATTACH][ATTACH=CONFIG]48401[/ATTACH]
                            Do you have a copy of the firmware? also do you have instructions for removing the laser unit? Thanks in advance.
