5560 CE40
  • tnrtt
    • 156
    5560 CE40
    Checked 08-2528 to 2531. All zeros. Checked 05-2731 all below 628. Set 08-2486 and 2561 to zero. Go in to 04 to print test pattern and it throws CE40. Checked developer and transfer belt springs. developer looks fine visually. Checked corona grids and charge scorotrons. Set 08-2528 back to 1. Ran a 05-2742 without error. Rebooted and got the CE40 again. Lost and need help.
    • 23010
    Re: 5560 CE40
    When you get the error, pull out the primary transfer belt and look at the patches. The answer should be obvious. =^..^=
    • tnrtt
      • 156
      Re: 5560 CE40
      None, BC. Didn't pull belt until I tried to enter 04 mode per troubleshooting steps. Don't understand why it wouldn't go in to 04 mode, yet ran a successful 05-2742.
        • 23010
        Re: 5560 CE40
        Sorry, I don't understand your answer.
        "None" means there's nothing on the belt? =^..^=
        • tnrtt
          • 156
          Re: 5560 CE40
          Nothing on the belt
            • 23010
            Re: 5560 CE40
            That would be a big problem. I'd say laser, for two reasons:
            1) On digital machines laser writes the image areas.
            2) Loss of primary charge would give you solid fill pages.
            So you'll need to determine if the transfer belt is turning.
            It's possible that the developer drive isn't turning, but that should include developer density errors.
            It's possible that the drum drive isn't turning, but again that should record a code.
            And the laser shutter might not be opening.
            That's about as specific as I can be with those observations.
            You will be able to see the drums and developers rotating through the front, with the front cover off.
            • tnrtt
              • 156
              Re: 5560 CE40
              Drums and developer rotating. Didn't check if transfer was rotating, my bad. Laser shutter worked in test mode. All that aside, I'm wondering why can't I get in to 04 mode and why I have a completed 05-2742.
              • tnrtt
                • 156
                Re: 5560 CE40
                I have an intact 5560 trade in. I'm going to take the process unit, transfer belt unit, Logic board and laser unit with me. I'll let you know what I find. Thanks for your help.
                • gliderider
                  • May 2015
                  • 131
                  Re: 5560 CE40
                  I would go after the transfer belt first. Those were know for issues with the rear transfer roller blocks separating which would lead to a lack of transfer. There was a bulletin regarding this. You can check this without removing the belt from the belt unit itself. I've replaced as many a three on one transfer belt assy.
                  • tnrtt
                    • 156
                    Re: 5560 CE40
                    I've ran into the block problem several times. Super glued them and a layer of epoxy after. Works great. Always the black for me. Closer proximity to the fuser, Heat stress I guess. Not my problem
                    • Blizzoo
                      • Aug 2013
                      • 611
                      Re: 5560 CE40
                      To add that the transfer belt drive gear screw that holds it in place can become loose over time preventing the belt to turn. It could be a case of just tighten that screw, seen that before several times.
                      • tnrtt
                        • 156
                        Re: 5560 CE40
                        Problem was the logic board.
                          • 23010
                          Re: 5560 CE40
                          I would not have predicted that. Thanks for posting back, and congratulations on your success. =^..^=
