2550c light copies black
  • bruce 49dcs
    • Jan 2017
    • 140
    went in a week ago to very light black copies and prints i ran the toner motor for a minute copies where perfect so i calibrated the dv at that level it lasted a week and now is light again is there a 08 code for amount of toner drop to dv or what am i missing
    thanks as usual for any thoughts
    bruce
  • gliderider
    • May 2015
    • 131
    Re: 2550c light copies black
    Sounds like you are just papering over an underlying problem. You made no mention of where the copier is at in its pm schedule. Are you at or over pm and/or drive counts for this copier? Did you remove, inspect and clean the charger assy?
    • bruce 49dcs
      • Jan 2017
      • 140
      machine has 26k total 20k black 6k color charger looks fine spiked dv with toner imediatly looks fine gets light a week later
        • 23009
        Well that developer is 8 years old, and not stirred very much. I'd check the developer bearings to make sure they aren't leaking, then change the D-FC30-K. =^..^=
        • bruce 49dcs
          • Jan 2017
          • 140
          oops turned out to be a defective toner all is well thanks for the input
