Toshiba 2830c - Display/Op Panel blank.
  • Pete from Prescott
    • Feb 2012
    • 26
    Toshiba eStudio 2830c
    Powers up, Lights in right side upper corner of panel light up, but no display.
    Worked on Tosh for years but have been away for some time doing Canons. Do these op panels just go bad?
    Thanks for your help folks!
    Pete in Prescott, AZ
    USMC 70-75
  • aalex_bom
    • Jan 2008
    • 214
    Re: Toshiba 2830c - Display/Op Panel blank.
    USMC 70-75
    check HDD or RAM stick on controller,
    should be rebuild firmware if the HDD fault.
    good luck.
      • Feb 2012
      • 26
      Not sure I understand...
      ..."should be rebuild firmware if the HDD fault".
        reload firmware
          • 22997
          I just changed a HDD on one of these last week. It was an 80GB SATA Drive.
          That being said, even if the machine is in perfect condition it's hard to justify spending any money on it. It's been obsolete for over 5 years. The last remaining machines are just limping along until they die.
