Reduced image through Doc feeder
  • bcopier2815
    • Oct 2015
    • 42
    I am working on a OKI CX3535 (Toshiba rebadged)Copy off glass is perfect but when using the document feeder the image is reduced about 1/4 inch. I can't seem to find an adjustment in the manual. Any Thoughts?
    • 23006
    Re: Reduced image through Doc feeder
    That looks like an eS3530C. I'll take a look when I'm in front of the laptop. =^..^=
    • bcopier2815
      • Oct 2015
      • 42
        • 23006
        05-3042 adjusts the subscan ratio (DF motor speed: enlarging or reducing the original image length). I used that adjustment just today on a eS4508A. I just wasn't sure if it applied your machine. You may also need to adjust 05-3044 also (write start subscan). =^..^=
