Where do i have it? for pro.
  • MUMMIM
    • Jan 2008
    • 125
    Hi all Pro. Tech !
    I look for codes after "line adjustment mode" maybe it is "2 level code", Pm me if any idea.
    Thanks and Best Regards.
  • ANOL
    • Jun 2016
    • 17
    Re: Where do i have it? for pro.
    wow !
    i am not pro. so not idea
      Originally posted by MUMMIM
      Hi all Pro. Tech !
      codes and procedure is in the manual
      what MODEL are you talking about?
      • MUMMIM
        • Jan 2008
        • 125
        In the manual isn't show it, the manual is only show before "Line adjustment mode" code.
        ex. 08-968 when 203 -1 at e230-232-350....
        Need for series have 4 number codes . from e 206 ...
        any idea else
        Thanhs.
          any idea else
          Thanhs.
          look in ADJUSTMENTS
          i have never seen a Tosh manual that doesn't cover line adjustment
          did you clean the patch sensor?
            • 23010
            Line adjustment mode for eS206 is 08-9010.
            So what is this line adjustment mode used for? Neither manual explains what it is for.
            • Thayer
              • Dec 2017
              • 108
              "Line mode "
              Is usually used to turn off meter counter, but doesn't allow machine to calibrate.
              Allows tech to run prints and not add clicks on customer.
              Be careful and remember to turn it back off. Otherwise customer will be getting lots of free copies.
              • tsbservice
                Field tech
                • 8056
                Originally posted by Thayer
                "Line mode "
                Yep I believe so at least it was when I was doing Toshy.
                • Vincent128
                  • Sep 2015
                  • 350
                  0 - for factory shipment (meaning normal operation after leaving the factory)
                  1 - for Line (meaning for use of the engine while it's still in the the Production Line - Most notably, it disables the total counter)
                  • MUMMIM
                    • Jan 2008
                    • 125
                    Hi all !
                    Understood ! it is very importance when we use line adjustment mode. So i don't write direct here about it.
                    anybody haven't used it - don't put that code.
                    This code is deep interpose the machine, open some code or mode that been hidden by Toshiba. It can clean and reset sensors, machine, correct some wrong which 08 code can't.
                    i wrote : maybe it is "2 level code". any idea else?
                    i am looking for it, if anybody have (machines number 4 code), pm me pls.
                    Thanks all
