5005AC passwords
  • tnrtt
    • 156
    5005AC passwords
    Repo from closed business. Admin and service passwords have been changed. Won't let me access either service mode. Is there a secret service code? Any help would be great. Even tried putting one of those little keyboards to try and directly access 08 mode.
  • Thayer
    • Dec 2017
    • 107
    Re: 5005AC passwords
    Hold down "home" and "start" keys and power on.
    #1048# should be password if that doesn't work leave it blank and hit okay.
    look for password reset
    • tnrtt
      • 156
      Already tried that. Thanks anyway.
      • Thayer
        • Dec 2017
        • 107
        You said you put on a key board, how about holding down 4-8-9 and power on? I used this on the 4555c series.
        • tnrtt
          • 156
          Just tried it. No difference
            • 23008
            That went away with the Weisshorn High machines. =^..^=
            • tnrtt
              • 156
              If you don't know BC, I'm screwed.
                • 8197
                If you format the SED-HDD and reload the firmware, I am not sure if this will reset the password. That might be on the System board.
                • tnrtt
                  • 156
                  That was my first thought, but can't get past the password. BTW, does anybody know where that's located? System, Logic or HD.
                  • MUMMIM
                    • Jan 2008
                    • 125
                    there are all in service manual, guy.
                    • tnrtt
                      • 156
                      Do you think you can clue me in? I can't find it.
                        • 23008
                        From what I've read, you must have EITHER the Admin password or the Service password to reset the other. If you have neither, the only procedure is a call to the Toshy Hotline. (Thank you Thayer) =^..^=
                          • 8197
                          ... this is the risk of buying used equipment. Sometimes you buy a brick that is only worth the parts.
                          As security concerns tighten about the use of default Admin passwords, the chances of buying a brick increases.
                          • tnrtt
                            • 156
                            That's what I gathered from the manual. No secret button sequence? There HAS to be a back door. I have a couple of junk machines here. I'm going to find out where the password is located. Thanks for the non smart ass answer.
                            • tnrtt
                              • 156
                              We were carrying the lease. They didn't want service included, saying they had a tech. Never heard from them until we picked it up from an empty office. I have a feeling their tech was screwing with whoever picked it up.
