Dispose of used toner
  • Reeves
    • Apr 2012
    • 277
    [Misc] Dispose of used toner
    I have a Toshiba estudio450 displaying Dispose of used toner I have replaced a new waste toner bottle I have cleaned the waste toner full sensor have reset the counters still the message keeps on coming what could be the problem
    • 22705
    Re: Dispose of used toner
    Wow! What an antique! Is this in a museum? =^..^=
    • tsbservice
      Field tech
      • 7635
      In Zambia? Maybe state of the art not antique.
      Reeves don't remember well that model but additionally to WTB full sensor there may be some sensor for actual presence of WTB itself. If this isn't working machine cannot recover from previous faulty condition.
      Check that and also remove the drum and vacuum drum cleaning section making sure waste auger is not backed up.
      • Vincent128
        • Sep 2015
        • 332
        Our main office copier here at the shop is a 450 ... it will NOT die. I keep waiting for something to die on it or run out of toner but the damn thing has run without issues for years and years.
          • 22705
          The most common thing I remember is the customer unplugging the waste sensor, since the wire hangs out in full view, just begging to be fiddled with. =^..^=
          • arnh79
            • 459
            I believe there is a secondary detection for waste toner full on those machines. If the waste toner auger is pushed towards the rear of the machine it activates a sensor that will also cause "waste toner full" message. Check if there is backup in the cleaner assembly and if the spring loaded auger moves back and forth freely. (I'm going from memory here, so I may be all wrong on this!)
            Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
