Identify firmware 2555c in the unzipped file
  • phucnguyen
    • Jan 2021
    • 17
    I have a set of fw including 2555c,3055c,3555c,4555c but they are combined into 1 file. i can't determine which one is the 2555c. Can you help me determine the fw 2555c as well as the rest. Mainly need 2555c first to use
  • clint@clintsimonsen.com
    • 124
    Re: Identify firmware 2555c in the unzipped file
    Put all files on usb stick in folder the 2555-5055 are all the same files
    Sent from my Nokia 8.3 5G using Tapatalk
    • phucnguyen
      • Jan 2021
      • 17
      Are all these files shared or not, does that mean they can be used for all 2555c?
        • 23006
        Well, this is the most current firmware and you don't have that:
        version 2191
        FIN1036T.030
        FIN1107T.109
        FIN1108T.207
        H576DFWW.09
        PUN6104T.401
        SDL1108T.302
        signatures_H.sig
        T210FWW.39
        T210MWW.84
        T212HD0W2191.tar
        T212SF0W2190.tar
        T212SLGWW.14
        version_H
        I don't have copies of v2162, so the next most recent is v2155:
        version 2155
        FIN1036T.030
        FIN1107T.109
        FIN1108T.206
        H576DFWW.09
        PUN6104T.401
        SDL1108T.033
        signatures_H.sig
        T210FWW.39
        T210MWW.78
        T212HD0W2155.tar
        T212SF0W2153.tar
        T212SLGWW.13
        version_H
        ... and yes, there must be a folder on the root named 2050C_5050C with these files inside.
        If I wasn't sure about which firmware files to use, I'd just start with a fresh download ... especially since none of these is current. =^..^=
        • tryn2survive
          • Jul 2021
          • 1
          version 2191
          FIN1036T.030
          FIN1107T.109
          FIN1108T.207
          H576DFWW.09
          PUN6104T.401
          SDL1108T.302
          signatures_H.sig
          T210FWW.39
          T210MWW.84
          T212HD0W2191.tar
          T212SF0W2190.tar
          T212SLGWW.14
          version_H
          version 2155
          FIN1036T.030
          FIN1107T.109
          FIN1108T.206
          H576DFWW.09
          PUN6104T.401
          SDL1108T.033
          signatures_H.sig
          T210FWW.39
          T210MWW.78
          T212HD0W2155.tar
          T212SF0W2153.tar
          T212SLGWW.13
          version_H
          I would love to know where I can get my hands on the latest firmware, I don't have a toshiba tech account but I'm trying to help out a friend who's printer's drive got zapped after a power failure and they are a small business barely able to make it without large bill from toshiba haha.
            Become a CTN contributor and I'm sure someone will help with your request.
              • 8193
              If the HDD died due to the result of a power surge, it is likely you need to replace the same with a Toshiba proprietary Secure Encrypted HDD. An off the shelf HDD will not work.
