E457 FW installation
  • copycart
    • May 2009
    • 97
    I have a F520 code on my ES 457, I have the firmware installed on a 16gb USB and when I insert in the copier and pull up mode 49, I get the message that, No Data is on the USB storage device. I have also tried a 2gb usb and get the same problem
    Re: E457 FW installation
    have you followed the firmware instructions in the manual?
    is the 2gb usb formatted in FAT32?
    are the files unpacked?
      • 23008
      I have several USB's in my computer case, and inevitably I choose the one with nothing on it, lol.
      But seriously, make sure its USB2, not USB3. The smaller the stick the better, 2GB works great. FAT32, without multiple partitions. There should be a folder on the root named 2050_5050 (I think). When you extract the firmware you'll see the folder.
      Did you format the drive? =^..^=
