Es2523 rotate long time
  • riyadh hossainbd
    • Dec 2015
    • 239
    Hi
    Recently I faced a common problem in some new machine ( copy counter about 2k,3k).
    Problem is after delivering paper, machine rotate long time about 20 seconds.
    If command 10 copies, problem occur after delivering last copies.
    Different location machines, but same problem, all machines are almost new
    • 23008
    Re: Es2523 rotate long time
    Why do you think something is wrong?
    What's the current toner level? (Let me guess ... 1%) =^..^=
      • 8206
      ... is there a Toshiba original T2323U OEM toner in the copier?
      The copier ships with a 2k starter toner at 5% coverage so it is quite possible the toner is very low.
      • aalex_bom
        • Jan 2008
        • 214
        check toner supply rate or fuser temperature
