3015AC CA00
  • patterson70
    • May 2010
    • 603
    Thank you very much for this. Lol about the side eye! Ok, I will let you know what the result is.
    Question: is the Shutter Assembly mentioned previously accessible from the side as well? I am pretty sure there is a problem with that as well.
    Please see the example pictures.
    • Vincent128
      • Sep 2015
      • 349
      It is, as noted by another poster, you can get the assembly out without taking everything out. I like to make sure everything is where its suposed to be so I dont have to make a return trip anytime soon and also that wiring harnness can get in the way of removal and re-insertion. I prefur to completely remove the shutter assembly so I can clean well the mating surface for the tape. Your mileage may very
      • Blizzoo
        • Aug 2013
        • 610
        Do you have error CA00 as well or just that bad quality on your examples? If just the quality it can be improed or resolved by doing a simple calibration, first use green wand from inside front door and clean the LSU slit glasses, remove the transfer belt cleaning unit (must be removed first) and then the transfer belt unit itself, the two sensors can be cleaned easily by pushig the black shutter by hand to reveal them. The sutther is at the top of the paper guide right under transfer belt. A picture below I could find - you look at it from position 11 and shows the sutter I meant abouveimage.png zz0.wa7v1bqpjmkzz
