3015AC CA00
  • denn
    • Nov 2020
    • 2
    3015AC CA00
    We have machine that trows CA00 each time i try to do FS-05-4719 (Forced performing of color registration. All colors formed on transfer belt(photo in attachment). FS-05-4720-0 returns 85: All colors on the rear side detection abnormality. I did check rear side sensor and cleaned it couple times. In 03 it show that the sensor is not working, front and center is lighting up. I have heard that it's very unlikely that sensor went bad. My question is did anyone change this sensor or have any ideas what to check next?
    Machine is 2 years old, has 170k copies and brand new dev-kit black and new drums and grids for colors(before replacement it also gave CA00).
  • mojorolla
    The Wolf
    • 2630
    Re: 3015AC CA00
    It is rare for these to fail. I believe these sensors are the same so you could swap front and rear and see if problem moves with sensor....
    • arnh79
      • 469
      Re: 3015AC CA00
      It might be worth checking the shutter assembly for the IQC sensors. There is a weakness on the first version of that assembly. The pin that the shutter swivels on breaks. Do an output test to see if the shutter moves. If the shutter doesn't move then you'll get CA00 because the sensors are looking at black plastic instead of the belt. I've had this happen on 2 machines in my territory.
      Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
      • Claudio_Napoli
        Toshiba Copiers Technical
        • Jun 2020
        • 27
        Re: 3015AC CA00
        e-STUDIO2515AC/3015AC/3515AC/4515AC/5015AC
          • 23010
          Re: 3015AC CA00
          +1 on this. I've MacGuyvered one of these myself. The post that the lever swivels on breaks off. Do I have a photo? Yes:
          I had a shoulder screw just the right size. =^..^=
          • denn
            • Nov 2020
            • 2
            Re: 3015AC CA00
            [ATTACH=CONFIG]49401[/ATTACH][ATTACH=CONFIG]49400[/ATTACH]
            You guys were right it was the shutter not opening fully.
            Fixed it the same way with a screw.
            Thank you for help 🙂
            • Rusty.Harris
              • Jan 2021
              • 638
              Re: 3015AC CA00
              2nd that as well. I've seen that a few times on the 05C series machines as well.
              • Bicyclerepairman
                • 63
                Re: 3015AC CA00
                I've had an issue with these sensors units where the harness wire was pinched causing a color registration issue. Not sure if it threw a CA00 or CE40 but the gamma chart looked freaky...the color blocks did not line up at all.
                Re routed the harness to fix...seen this happen twice.
                • Pirate1936
                  • Oct 2019
                  • 9
                  • Pirate1936
                    • Oct 2019
                    • 9
                    Re: 3015AC CA00
                    Photo for previous post...
                      • 23010
                      Re: 3015AC CA00
                      Nice mod.
                      • marn1980
                        • Jun 2021
                        • 3
                        Re: 3015AC CA00
                        CE40,CA00 need to clean a LED print head and LED discharges. Normally you need to disassembly LSU UNIT to clean toner dust and d/v. Another thing make sure TBU UNIT not broken.
                        • patterson70
                          • May 2010
                          • 603
                          Originally posted by marn1980
                          Re: 3015AC CA00
                          Thank you for this information. I know it is am old posting but could someone tell me how to get this unit with the shutter out of the machine? I am not a Toshiba Tech but have a 3015 with this issue.
                          • Vincent128
                            • Sep 2015
                            • 349
                            I like to take the entire right side of the machine off, take out all process units, fuser, ITB cleaner, ITB, laser, erase LED tray - sounds like a lot but it's like 10 mins of work. Unclip the harness from inside the machine, two screws hold the sensor assembly on and if you wiggle just right it will come off from its pins pretty easy without removing the registration roller. With everything out of the machine it's nice and easy to get the vac in there and make sure the waste collectors and HV connections are clean and I generally open the registration and transport sensors and clean/inspect etc while everything is nice and accessible. Customer will give you the side eye as you just gutted the entire machine.
                            • djbass
                              • May 2008
                              • 167
                              That's way too much work LOL
                              I just remove the transfer belt assembly, undo the two screws on the guide and pop it out.
                              These days I just use the bracket mod (6LK50637000) , you don't even need to disconnect the harness.
                              No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
