eb50
  • david@fredz.co.za
    • Nov 2020
    • 3
    eb50
    is anyone having eb50 errors on the new range toshiba's especially 6518 and 8518
  • MarkG52
    • Oct 2017
    • 29
    Re: eb50
    No sir
      • 23008
      Re: eb50
      EB50's are usually doublefeeds. Has you're separation roller gone flat? =^..^=
      • david@fredz.co.za
        • Nov 2020
        • 3
        Re: eb50
        I have replaced the feed wheel pm kit, the feed clutches and paper detection lever. The machines run like 1000 prints no jams so I leave the client but before end of day they have called back wit same error. I have also adjusted the separation tension on the feed section.
          • 23008
          Re: eb50
          How did you adjust it? For additional page separation, you want less tension on the spring. =^..^=
          • Blizzoo
            • Aug 2013
            • 608
            Re: eb50
            Adjusting that separation spring tension helps with this double feeding. Decrease the tension a bit more as blackcat said for a better separation, you will probably see the separation roller getting wear down much faster
