ES5005 F550 code and jams if more than 1 copy/print
  • Toshcopierfixer
    • Jan 2016
    • 5
    [Jamming] ES5005 F550 code and jams if more than 1 copy/print
    ES5005 everything you print or copy more than 1 copy it will feed the first sheet but the second (& on) will never leave the tray(s) it will time out with a F550 jam code no paper leaves the drawers but machine shows paper jam multi sheet feed. You have to reboot to reset machine. Shows up in report. ALL clutches Fine ALL sensors Fine
    Logic Board?
