e-250 Scan not working
  • Claudio
    • Feb 2007
    • 235
    Good morning:
    I have another question for this e-250 copier. I hooked up the printer using a static IP set to RAW 10001 with PCL driver. Printer working fine on the network. I have downloaded the Viewer program, then the upgrade service pack 1 then service pack 6. It will not detect the scanner. The fax is receiving ok.
    Does anyone know which setting I should check or what I need to do to get the scanner working?
    Thanks for your help. Have a great day : )
    Claudio
  • copytechman
    • Nov 2008
    • 947
    Scanning as described can only be done via the parallel port on that device.
    Parallel port w/toshiba viewer + fax board has to be installed.
    There is no network scanning unless the ifax kit is installed inconjunction with the network kit... which then disables the parallel port.
    Regards!
    A.
    • Claudio
      • Feb 2007
      • 235
      Copytechman:
      Thanks you for your prompt reply.
      I am now in the process of looking for my old parallel cables
      • Claudio
        • Feb 2007
        • 235
        Copytechman:
        That was it!
        The scanner now works.
        Thanks again.
        • copytechman
          • Nov 2008
          • 947
          Your quite welcome.
          Glad to help!
          Regards!
          A.
