Es2508 ROM RECOVERY firmware
  • riyadh hossainbd
    • Dec 2015
    • 239
    Hi
    Recently i face a problem, I can't update firmware normally. I think I need alternate way to update firmware, Does any one have ROM RECOVERY firmware ? Willing to pay.
    Thanks in advance
    Sent from my ELS-NX9 using Tapatalk
    • 23008
    Re: Es2508 ROM RECOVERY firmware
    Did you try a new USB2.0 stick, formatted FAT32, 2GB or less in size? Have you tried the other USB port on the print card? It sounds like the machine is not recognizing the USB stick. =^..^=
    • riyadh hossainbd
      • Dec 2015
      • 239
      I input normal firmware in usb flash drive . I think in this recovery mode normal firmware do not support, Machine need ROM RECOVERY firmware.
        • 8197
        I think the USB drive you are using is corrupted. Buy a new one or format the one you have and try again.
        If you use the same USB drive over and over and do not eject it via right click rather than simply pulling it out of a computer there is a high chance you have corrupted the USB drive.
        • Blizzoo
          • Aug 2013
          • 608
          Your PM inbox it's full....
          Can you share your email address via PM?
          • riyadh hossainbd
            • Dec 2015
            • 239
            Many many thanks to you
